ReekieVR 0 Posted October 2, 2006 Which is for what? My 5 amp blows as soon as its replaced. At least i rekon i found the hot start issue ! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 2, 2006 That's for the run-on circuit. (The bit that runs the fans and the aux water pump and fuel pump after the ignition has been switched off.) Not sure which fuse is which. I thought there were three fuses though? Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 2, 2006 The 5 amp is for the electric water pump behind the coil pack, probably a faulty pump as that is very common. I replaced two last week and when they fail, the heater matrix often goes pop! Quote Share this post Link to post Share on other sites
ReekieVR 0 Posted October 3, 2006 Cheers crasher. Just the info i needed. *Title edited in light of drmats correction* Quote Share this post Link to post Share on other sites
