Nick
G60 Temperature gauge.
What sort of temp should i expect my 91 G60 to sit at once warm?
Its been so long since it worked, ive forgotten. :oops:
Seems to sit half way between 70 and 110, which im assuming is right, but want to double check, incase i cook everything!!!
Nick
sorry to butt in, when i running my temp sits at bout 70, when i am stuck in traffic it goes up to bout 90 is this right also ive never heard the fan kick in, btw ive only had it on the road for two weeks.
yeah i cant recall hearing it kick in, sometimes i can be driving for quite a while and my temp wont even go up to 70 so i guess ive got a prob.
lamwagon, change the black temp sender first, they under-read with age, do the blue one as well if it's not been changed recently...
If you then find that it runs at 90 but gets to 110 in traffic then change the rad fan thermoswitch (yours is only working at stage 2)
it may also be the t/stat stuck open, check the bottom hose on the rad from cold if it worms up as the same time as the rest of the hose's then its time for a new t/stat
also open the bonit went its up to 90 and see if the fans running as you my not hear it
