2corrados
VR6 Piston ring compressor
HI
Anyone got a vr6 piston ring compressor, so my mech can put the new rings in next week.
Happy to buy a cheap one, or pay to borrow one
Many thanks if you have.
Dic
:D
Any piston ring compressor should do, as long as the diameter can be adjusted to over 82mm. When I did my engine rebuild, I just got one from the local motor factors, wasn't expensive...
thanks guys, was thinking about your 2 options, and did the first from tug this afternoon, and will be doing the second from James tomorrow.
cheers guys, there's always the info about when you ask
Dic
I found that cos the bores are on an angle to the head mating surface it's possible to do it without a compressor, by just putting them in a bit at a time and working the rings in from the highest point downwards, as you slowly push the piston down, if you know what i mean??????? Takes a little while longer but not too bad of a job......... Compared to some at least!
cheers trevr6, sounds like a plan to keep in mind. Mrs keeps making remarks like bit at a time and working the rings in, but thats a diffent forum. Thanks for the info
:ignore: :lol: :lol:
