mr_fusion 0 Posted October 5, 2006 Ok, weird one this. Here is the problem. Start up car, ABS light comes on and stays on. Plug in the VAG COM, try to connect to the ABS, cannot be found. Turn ignition off then on again, ABS light comes on then goes off like it should, connect VAG COM, finds ABS, no faults reported! This problem is totally conisistent. Only thing I might add is that there is a push button ignition start as the switch broke and would not work on the ignition position (so the push start button is pressed to fire the car up) I have a new switch so I can fit it at the weekend, but I don't fully understand how this would effect the ABS. I know everyone is just thinking "connect the new switch and see what happens" but I am pre-empting that this will not fix the problem and looking for other possible solutions as well. Any thoughts or anyone had a similar issue? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted October 6, 2006 mine used to do something similar, Go jet wash the wheels and brakes, always fixed mine. but i never had vag com Quote Share this post Link to post Share on other sites
mr_fusion 0 Posted October 6, 2006 I may have found a very useful bit of info on google! http://www.mightyautoparts.com/pdf/arti ... 20light%22 "VOLKSWAGEN WITH CONTINUOUS ABS LIGHT Volkswagen has identified that a problem with the ignition switch may result in the ABS warning lamp being illuminated on Passat, Corrado and EuroVan models from 1993. VW Bulletin No. 93.01 identifies that an ABS warning light which does not go out after vehicle start-up may be caused by the ignition switch/lock not fully returning from the “start” position (terminal 50) to the “run” position (terminal 15). If the switch/lock does not return to the run position, circuits controlled or powered by terminal X (for example headlights, evaporator fan and ABS hydraulic pump) will not function. A non-functioning ABS hydraulic pump will cause the ABS warning lamp to stay on. If the ignition switch binds or does not return smoothly from the start to run position, check for misadjustment of the shift/lock cable, an ignition switch sticking or binding, or a burr on an improperly cut and deburred ignition key." Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 6, 2006 That sounds like the bunny. You other possibility is the ABS power relay being a little sticky - it needs a second shove to get it going? Quote Share this post Link to post Share on other sites
mr_fusion 0 Posted October 6, 2006 Yeah, that was going to be my next option. From experience getting at the relays is a a whole lot easier than getting at the small screw that hold the ignition switch on.. Oh well, lots to do this weekend: Fix the ABS problem Oil Change Oil Filter Change Fit Mocal Oil Cooler Kit (if it actually arrives today!) Bit of sanding, filling, painting of O/S rear wing (if weather permits) Same for both bumpers. Quote Share this post Link to post Share on other sites
kongo127 0 Posted October 6, 2006 mr_fusion, Nice Find! Quote Share this post Link to post Share on other sites
Guest Posted October 6, 2006 I have a similar inconsistant error on mine. I had a dodgey connection on my headunit, and the battery kept running flat, and after a few times of jump starting the ABS light came on. I fixed the live feed problem, and now the ABS stays on every couple of days, but is fine when I come back to it. I was thinking the power problem buggered up the ABS Brain? Quote Share this post Link to post Share on other sites
mr_fusion 0 Posted October 8, 2006 Good News. Swapped the ignition switch, ABS now works perfectly. Definately something to think about if anyone else has an ABS light problem. Quote Share this post Link to post Share on other sites
