Bobby 0 Posted October 24, 2006 Does my 1.8 valver need an emissions test for mot, if so what the limit before it fails as my car is set up rich from when i was running the 16vt lump, co2 is set at 2ish. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 24, 2006 Does my 1.8 valver need an emissions test for mot, if so what the limit before it fails as my car is set up rich from when i was running the 16vt lump, co2 is set at 2ish.# yep, but it's not as stringent as for a car with a CAT post 1992, 2% CO should pass OK, think 3.5 is the limit for a non CAT car. Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted October 24, 2006 Mine failed MOT for the emissions a couple of years ago. Quote Share this post Link to post Share on other sites
Bobby 0 Posted October 24, 2006 i'll need to get it double checked as my sparkies were black when i changed them yesterday, think its slighty over fueling, when i accelerate quick and put the clutch down the revs come down slowly is that a sign over overfueling? Can normally hear a hissing noise when i turn the engine off, checked for vaccum leaks but couldn't find any might be the drilled airbox releasing the pressure? Quote Share this post Link to post Share on other sites
ben16v 0 Posted October 24, 2006 mine set at 2% and i never had a problem Quote Share this post Link to post Share on other sites
