blackboy VR6
LOSING WATER
started losing water on my vr6 no white gunge on dipstick very little on the oil filler cap (small amount can be expected as i only do 3m to work everyday) filler cap clears off white stuff if i take it for a decent run, cannt see an obvious signs of water leaks, no loss of power (that ive noticed) is there any usual spots i should be looking
help please
"Usual spots":
- heater matrix hose at the back of the cylinder head under the cable tidy (this is #1!)
- aux electric water pump
- expansion tank cap
- heater matrix (as stated above) ...
- thermostat housing
- water pump
.. plus the big, obvious ones like the rad ..
the header tank. mine leaks slightly along the joining lines of the top and bottom half just behind the black cover with the picture of a book on it
