samg60 0 Posted October 29, 2006 just been reading the latest copy of the golf + and there is a seat ibiza with a 20vt it has had a metal wheel in replacement of the plastic original item on the water pump, anyone know where I can purchase these. Quote Share this post Link to post Share on other sites
nia573 0 Posted October 29, 2006 Haven't the plastic impellers been superceeded with the metal versions, since there were lots of cases of them shearing off?? A call to the dealers or someone else might confirm tho' Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 29, 2006 Pattern, metal and genuine exchange plastic. Quote Share this post Link to post Share on other sites
andy 0 Posted October 30, 2006 ?? nia 573 is right Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted October 30, 2006 I was advised to do this on my wifes lupo by vince from stealth whilst i was having the cam belt done. I got mine from german and sweedish Quote Share this post Link to post Share on other sites
samg60 0 Posted October 30, 2006 cheers lads, assumed is it was a aftermarket as it was lisetd in the spec list and also people are always goijng on about it beinga weak point of 20v engines, cool as long as I know its a genuine VAg I will order a replacement when I do the Cam belt in 6 months Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 30, 2006 Plastic is a stupid idea when it comes to coolant components. It's tight arse manufacturers trying to save money (for them, but not us). The problem with those is the edges of the blades wear down quickly, reducing the flow and many engines take a temp reading for the dash from a plastic stat housing, so the guage won't show any different, but the reduced flow could be causing localised over heating at the back of the block. Cr@p design. Replace it with a metal one ASAP! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 30, 2006 So is this a case where the pattern part is better than OE? Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted October 30, 2006 sounds that way to me Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 31, 2006 Yes. VR6 pumps from GSF are metal. I wouldn't be surprised if overheating VR6s are caused by worn plastic impellers. Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted October 31, 2006 it was only £30 for the lupo so i thought I may as well do it while the cam belt was being done, how much are they for a VR6, and does anyone know weather the 1.8 16v engine uses plastic or metal impeller Quote Share this post Link to post Share on other sites
