madscientist 0 Posted October 31, 2006 Another leaking Vr6 :roll: I found a small leak on the oil cooler to plastic pipe hose but when i was moving it the plastic transfer ipe moved as well and now leaks coolant from the water pump end, is it just the seal thats gone? Should this pipe be able to move round like it does or should it be fixed in place? Also how do you get it out? Thanks Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 31, 2006 It will be the "O" ring that has failed but to replace it you have to remove the thermostat housing.I should move a little. Quote Share this post Link to post Share on other sites
