morpheus20170
Gearbox/clutch problem
I have recently had a VR6 clutch fitted to my G60 and since picking it up it doesn't seem much better, I also asked the guy to put 2 litres of gearbox oil in it which I gave him, Motul stuff.
When I picked the car up and drove it away I found the speedo to not be working which worried me especially as I was driving on the motorway, since he has come back and seemingly replaced a sensor the speedo never goes below 10 mph but I am unsure where it should sit when sitting in traffic for instance.
Can anyone please tell me what to do and advise me if as the mechanic has said, that the syncros are needing looking at that this would be the reason or could there be something else, can the gearbox be fitted wrongly, I am not accusing this guy of wrong doing but I am concerned.
Thanks to all
Paul
It may just need bleeding or at the worst a new master or slave cylinder. The speedo fault is odd though, I have seen this on cable speedo cars where someone has tried to start the car with the main earth lead off. This causes a drain of current through the speedo which heats up the return spring and prevents it returning to zero.
