claire.major
Charging problems
Hi
Only fourth post and problems already!!
Had a flat battery (interior light on!) so jumped the car from our daily and took it out for a drive to get some charge 5 - 10 miles and when I got back the battery had about a minutes life in it until it was completely flat.
Think it could be an alternator problem but wanted to check for any other ideas before i buy a new alternator!
Any suggestions what to check would be great help
Cheers
How about doing some basic tests with a multimeter (£4 in maplins) before you spend £100 on a an alternator?
Engine running:
- 13-14V across the battery terminals means your alternator is fine.
Engine stopped:
- 12.6V across the battery terminals means your battery is fine (and fully charged).
- less than 11.75V across the battery terminals means your battery is fully discharged
- less than 11V means you have dry/dead cells - time to replace the battery
Aye 8)
May just be £10 quids worth of voltage regulator on the alternator...available from gsf or vw (bit more cash).
ps:to add to the above post,you want around 13.8v from the red lead on the alternator...much less and its a sign of a dead voltage regulator.
Neil.
