Saint Tricky 0 Posted November 5, 2006 Hi Got a 92 G60. Oil temps are really high, and i don't believe them. Takes 3 miles of normal driving to get to 80 degs. Another mile and it's 120. Water is always around 95 deg mark when warmed up. If I put my key in the ignition after a long run the oil temp is 95degs, if I start the engine then it's 135degs. My readout fluctuated between 126, 134, 142, 150, 140, 126. In just a few seconds today. I took the car out of gear (so low revs) while going down a long hill today and the temperature increased. (doesn't make sense) I then dropped a couple of gears and planted my right foot and the temperature decreased. (eh?) Finally the fan comes on when the readout displays 120degs. Anyway, I assume there is some sensor somewhere telling my digital readout what the temps are and I think this is at fault. Appreciate if someone can read between the lines here and confirm or rubbish my conclusion. Thanks for your help. T P.S. Not using any oil or coolant either. Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 5, 2006 bet its a bad earth or dodgy connection causing dud readings Quote Share this post Link to post Share on other sites
Saint Tricky 0 Posted November 5, 2006 Thanks, I'll have a look. Sorry for the multiple post mods. Went a bit silly after getting the error messages and now the posts are coming up at random. Feel free to terminate any eroneous ones. T Quote Share this post Link to post Share on other sites
