Rcole 0 Posted November 8, 2006 Hi Someone recommended the forum as you guys know your stuff. Can anyone help, Ive had my valver for a couple of months and its suddenly died. (1993 2.0 16v) Ive replaced the dizzy cap rotor atm leads and plusg, Ive tested the feed to the dizzy and thats fine, but its still not firing up??? Its trying but the spark just isnt there. Can you recommend what else I can test or any ideas what the problem is??? Thanks in advance for any help Rob Quote Share this post Link to post Share on other sites
Toad 0 Posted November 8, 2006 Probably the hall sender inside the dizzy. It can be replaced, or you can buy a new dizzy. Where are you? someone might be able to lend you one so you can test that it is the problem. Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 8, 2006 Im in North Wales, Is it worth getting one second hand? Or arnt they that much new? Is there any way of testing it brfore buying one? Cheers for the help Quote Share this post Link to post Share on other sites
Toad 0 Posted November 8, 2006 To be honest, a second hand one *could* pack up again pretty soon. Your original one has lasted 13 years.... I'd try a new one, or putting a new hall sender in it. Search for hall AND sender for more information remember to put the AND in (in capitals too) Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 Ok now I am stuck !!! Ive replaced everything, new leads plugs dizzy cap distributor hall sender. There is feed going in through the sensor stuck to the dizzy and through the centre lead theres fuel getting to the plugs but she still isnt sparking. What is wrong :? Anyone .............. Quote Share this post Link to post Share on other sites
Saint Tricky 0 Posted November 13, 2006 Might be worth checking the earth strap from your battery to the engine hasn't bust or corroded. A long shot but a cheap check. T Quote Share this post Link to post Share on other sites
Toad 0 Posted November 13, 2006 Check the plug and the three wires running to the distributor. check the coil too, that could have broken down. I suppose it could be the immobiliser, if that's hooked up to the coil. Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 The car has not got an immobilizer, Ive had my electrical tester on the coil, thats fine and the three wires coming into the dizzy, two show earth and one shows live? Ive looked through the receipts I got with the car and the ignition barrel by the steering was changed in 2004. ANy other suggestions guys? Thanks so far. Quote Share this post Link to post Share on other sites
Toad 0 Posted November 13, 2006 I think the three wires should be earth, trigger wire to the ignition and feed to the rev counter. but I could be wrong. Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 Has anyone got a wiring diagram for the ignition???? Or know where I can get one from? Thanks again All info is v much appriciated and hope I can get her going again. Rob Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 13, 2006 ignition switch??? where in n.wales mate? Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 Ignition switch????? Im based in Wrexham. Your a bit far especially with my car not moving lol Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 13, 2006 read through this mine was turning over but no spark, there is a few people local to you tho. PM coolrado i think he`s pretty handy with rado`s. Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 without sounding too stupid, where do you mean by ignition switch?? Where is it based? as I said earlier the ignition barrel has been changed. Thanks for the posts though Keep them coming Rob Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 13, 2006 the ignition barrel is what you put your key in the switch is behind that and the contacts can corrade over time so the car will not start do a search for "ignition AND switch" Quote Share this post Link to post Share on other sites
Rcole 0 Posted November 13, 2006 Thanks is there any way of testing it before I buy one??? Would it still crank if the switch has gone?? There is no delay in turning the key and the engine attempting to start??? Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 13, 2006 they`re only £20 from VW yeah will still crank just not fire, on mine mechanic touched a live wire to the coil and it started on the button Quote Share this post Link to post Share on other sites
