B4LJX 0 Posted November 10, 2006 went out about 4 and parked the car up and just went out to move the car and it would start had a look the engine fan is still running and killed the battery jumped it no probs to move it any ideas where to start? thanks bal Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 10, 2006 Change the fan thermoswitch ( Have a search, there'll be a few threadds around about it :) ) Quote Share this post Link to post Share on other sites
bcstudent 0 Posted November 10, 2006 Make sure the fan thermoswitch connector hasn't come adrift and is touching an earth too. That happened on my 16v. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 11, 2006 Actually ignition-off fans are controlled by a different circuit. They are also supposed to be on a timer which means they'll only run for ten minutes maximum. Quote Share this post Link to post Share on other sites
B4LJX 0 Posted November 18, 2006 where about is this thermoswitch connector located ? Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted November 18, 2006 Had the same problem, if you look on the right side of ur radiator when ur looking at ur car, all the way at the bottom of the rad is a sensor/plug, unscrew that and replace it, coolant will come out so watch urself, its only like 12 buks us so like 6 pounds, i got the lower temp rating sensor, fan comes on earlier Quote Share this post Link to post Share on other sites
