DanVW 0 Posted November 13, 2006 Sorry if this has been covered before, have searched but cant find anything! Any fellow G60 owners changed your chargers small toothed belt? How easy is it, I am sure I read somewhere that these are cheap and easy to change an therefore should be changed once a year, I also heard that if you have a Jabba charger (like me) you should change it as they have a habit of not changing this belt when they are rebuilt? Cheers all Dan Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 13, 2006 im sure jabba would have changed it....its all the cheap bits they put inside you need to worry about as for swaping the belt...turn the pulley and you will see both shafts have a notch , the notches need to point at 12 o clock and line up with a line cast into the case...spin the charger by hand to confirm you got it right before starting up Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 13, 2006 Cheers Steveo :-) knew it would be easy! Just another quick one so I can plan roughly how long it will take.... Will I need to take the charger off the car to do it? Dan Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 13, 2006 you can leave the charger on, but you need to remove the main belt to gain access, the pulley needs to come off too i also took the airbox out to make things easier....took me well under a hour all in Quote Share this post Link to post Share on other sites
