Saint Tricky
Very quick oil temp question
Hi
Trying to trace the fault for my high oil temp reading.
Can someone check something for me please?
After having driven your car up to working temperature, before you turn the engine off make a note of the oil temp. Then turn the engine off and put the ignition back on (don't start the car though). Press the MFA button until the oil temp comes up, is it the same temp reading as when the engine was running?
Ta
T
yeah mine reads the same
Thanks Steveo, really appreciate it.
Mine reads about 25 degrees higher when the engine is running. I'm 90% certain it's a false reading, just need to work out why now.
T
