Dave_P
Throttle adjustment on a boost return deletion, G60.
Just wanted to know if any ppl here have adjusted the throttle rod on their throttle body to close earlier after fitting a boost deletion kit ? i`ve herd it can help the car run smoother ? Or does it just allow the boost to be dumped on lower throttle ?
Just want to know that if i adjusted it, could this leave me open to damaging the engine ?
trying to think of the machanical pricables in this... wouldnt it give i slightly quicker response to the throttle closing ? i can only see it dumping the air at lower gear changes as the butterflies closer to being on full throttle..
i dont think ill try it if no 1 else has tried it..
no it will only ruin your mpg. and over boost at low revs. leave is best.
i know. i sodded mine up by adjusting it. then i could only get 180 to a tank, and kept spinning the wheels at low revs..
do not adjust.
