andymc 0 Posted November 19, 2006 my passenger side front wheel appears to lean very slightly inwards at the top of the whhel, the vr6 is running on fk adjustable springs and dampers, im unsure to the correct name but hopefullt the picture will paint a thousand words, is there a bush/spacer missing at the top of the suspension mounts? sorry to sound thick but im not in the slightest mechanically minded Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 19, 2006 It will be the camber adjustment,which is adjustable via the top bolt that attaches the shocker to the hub,as for the picture the top mount looks like its worn but wont affect your camber. Having positive camber is normal depending on the severity of the angle. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 19, 2006 If the car is on level ground with the wheels straight then that top mount is foooked Quote Share this post Link to post Share on other sites
andy 0 Posted November 19, 2006 Yep you shouldn't be able to get your fingers under the raised caps, top mounts probably fooked. Quote Share this post Link to post Share on other sites
Crasher 3 Posted November 20, 2006 Having positive camber is normal depending on the severity of the angle The camber on a VR6 is -1° 20΄ Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 20, 2006 Having positive camber is normal depending on the severity of the angle The camber on a VR6 is -1° 20΄ :wink: Quote Share this post Link to post Share on other sites
