Andy T
VR6 ABS pump/valve block part no's
I need a ABS pump/valve block assy for my '95 VR6, I've read that the part no. is 1H2 614 217 A.
I've found one at a breakers that apparently came from a mk3 Golf VR6. its part number is 358 614 217.
Will this be a compatible unit? Does the '358' just relate to the vehicle model? I'm assuming the 'A' on the corrado number means its been revised once, does anyone know what the difference/compatibility is?
Is there anyone that could look the second number up on ETKA to see what model/engine/year it relates to?
Thanks.
358 is a Passat.
217A means you've got electronic differential lock (the abs acts as traction control as well as abs)
1h2 614 217A was fitted to a passat between 1992 and 97.
Thanks, what does 1H2 refer to though, are the first three digits irrelevant in terms of compatability, just a reference to the vehicle they came from?
Do you know which passat model/engine had the 1h2 614 217A unit?
Cheers.
