Dec
Cylinder head bolt tightening sequence (16v)
I've been looking through the Haynes manual and I cant find the tightening sequence for the head bolts on a 1.8L 16v.
Anyone have a link to a diagram? :wink:
if you buy a box of headbolts they often specify the torque/tightening method on them, e.g. stage 1 stage 2 then 180 degrees.
That torque settings list is incomplete is it not?
As far as I know the correct sequence is:
Stage 1: 40Nm
Stage 2: 60Nm
Stage 3: 90deg
Stage 4: 90deg
Stage 1: 40Nm
Stage 2: 60Nm
Stage 3: 90deg
Stage 4: 90deg
just added a note to my original reply (3) means 180 degrees.
