BoddersG60 0 Posted December 5, 2006 My k reg G60 is not starting. It had a new alternator a few weeks ago and a new battery. Now when I turn the key the dash lights come on but the engine doesn't turn over at all. Last week it failed to start and the AA guy said he thought it was a dead starter motor, the car bump started and has been fine since then but has not started again today (the car has not had a new starter motor). When driving the car the battery light flickers occasionally, I think there may be a loose wire somewhere. Can anybody help? Has anyone got any wiring diagrams? Thanks in advance. Quote Share this post Link to post Share on other sites
Lippy 0 Posted December 5, 2006 igntion switch - sounds very similar to a problem a used to have Try turning the car over but "lifting" the key in the barrell as you turn. This may not work depending on how knackered your switch is - there is a guide in the wiki for replacing. I'll fetch a link ... Quote Share this post Link to post Share on other sites
Lippy 0 Posted December 5, 2006 http://www.the-corrado.net/wiki/index.p ... eplacement the new part from VAG is just over 20 quid. Don't get any other one, as they still have the same problem. If you've removed the dash before you can do this in 40 mins or less? let us know how you get on Quote Share this post Link to post Share on other sites
BoddersG60 0 Posted December 6, 2006 cheers Lippy, I've got the part just got to fit it now. I'll let you know how it goes. Quote Share this post Link to post Share on other sites
Lippy 0 Posted December 7, 2006 no danger - hope it works out Quote Share this post Link to post Share on other sites
