mattkh
why 2 spades on solenoid
Hi
Why does my starter solenoid have 2 spade connectors ? Surely, one is enough to get the signal from the ignition switch to pull the plunger.
Thanks in advance.
One (the back one next to the gearbox) is for what is known as line 50 which is the solenoid command using the thick red/black wire. The other terminal (behind the radiator) is called 15a and is used as a starter cranking live output that was used on K-Jet models to power the cold start injector during cranking and had a black wire going to it.
Hi Crasher
You are a star,
So, if the cold start injector circuit uses too much current for some reason, there will be less current going through the solenoid, thereby less movement of the plunger.
Do you agree ?
