jimmy p
losing oil!
I bought my VR6 about 2 weeks ago, i've done about 600 miles since then and had to top it up with oil twice! Both times its been on the minimum mark and i topped it up to maximum. I've had a look for a leak and apart from a couple very minor ones that i can't see being a problem the engines clean. There is also not much smoke coming out the exhaust, only a bit when i first start the engine and when its cold. Also i changed the plugs the other day there was some oil on them.
Could this be the valve stem oil seals? :? I hope its not piston rings! :cry:
Well...
I´m pretty sure that this is not a normal situation.
I suggest a compression test to eliminate the piston rings and valve seals leak probablility.
Although piston rings are my first bet, they wear faster than the valve seals.
If it´s the piston rings, don´t get sad!
You only have the car for 2 weeks, and being like that, you´ll notice a huge difference with new ones! :)
So, go for the compression test before anything!
