cormjah
Hellish vibration when fan kicks in
My h plate valver has just developed a nasty fault. when the cooling fan kicks in after i've stopped there's really bad vibration. the fan doesn't sound too good at all, a bit grindy. at worst the whole car was throbbing after the ignition was turned off, v worring!
do i need to replace the whole fan or is it a case of replacing bearings? it's coming up to 140k. any suggestions?
Cheers
When this happened on my G60 it was due dry/worn bearings. I took it off and dripped some engine oil down the shaft into the bearings, left it for a while then put a permanent 12volts across it for five minutes, then re-oiled, worked perfectly quietly after that for years.
Ideally you should strip it and clean/grease the bearings, not sure if it can be done though.
