diggerbucket 0 Posted December 30, 2006 My ABS is not working at all, so I thought first thing to check would be the relay and fuse.... but where are they? :? Don't think I can see them in the fusebox? Quote Share this post Link to post Share on other sites
Crasher 3 Posted December 30, 2006 The fuses and relays are on a bracket behind the air ducting to the passenger’s side behind the glove box. Occasionally peoples feet can dislodge the fuses, especially after some, err, fun, in the passengers seat-if you know what I mean! I would suspect you have and ECU with water damage though. Is the ABS light on? Get a fault code scan first. Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted December 30, 2006 It's totally dead, there is absolutely no sign that the car even has ABS! No light, no vibrating pedal on startup, nothing! Fault code scan just says it can't communicate with the ABS. Quote Share this post Link to post Share on other sites
buttles 0 Posted December 30, 2006 As Crasher says it sounds like problem with ECU. Have you looked at the pins on the multi plug? Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted March 1, 2007 Tried another ABS ECU today and it's still totally dead, no light, nothing. Any other ideas? The 3 relays which are hidden in the passenger footwell - which ones are for ABS and are there fuses up there too? It was dry as a bone down there too so it can't be water damage. Quote Share this post Link to post Share on other sites
buttles 0 Posted March 1, 2007 The relay sockets have fuses in them as well. You can access them with the glove box in but it is much easier with it out and also it is quite easy to break the relay mounting. Can't remember which ones are for the ABS. Two I know, one for the pump and one for the system. Good luck Quote Share this post Link to post Share on other sites
Guest Posted March 1, 2007 scan the ecu memories before you do anything will give us a better idea whats going on and where to start Quote Share this post Link to post Share on other sites
buttles 0 Posted March 1, 2007 As he says..... he can't even communicate with the ECU so no joy there Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 22, 2007 Looks like my ABS is dead too - will have to have a rummage for relays and fuses tomorrow. If I find anything, I'll let you know :) Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted May 22, 2007 dinkus said: Looks like my ABS is dead too - will have to have a rummage for relays and fuses tomorrow. If I find anything, I'll let you know :) Please do...... mine's still broken :lol: Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 22, 2007 I also have the luxury of a backup ABS ECU so I can swap that out and see if it makes any difference... Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 23, 2007 Still no joy, so started a new thread with a more relevant topic here in the hope that it'll get a bit more attention... Quote Share this post Link to post Share on other sites
