Goldie
Carpet Cleaning
Right car cleaning wizzards i have a question.
Id like to shampoo the carpet in the car and would like to know:
Whats the recommended stuff to use??
Is there a procedure for doing this properly? I dont want to just end up with a wet foamy car!!
Cheers peeps.
Not having a wet and dry vac, I use Auto Glyn interior shampoo. It always seems to do pretty well on the nice beigh carpet in my C. I also use it in the house quite a lot. I used to use Groom, the spray foam stuff, but this always left watermarks on seat and headliner materials.
Phil
I dont have access to a wet and dry hoover either.
Did you find it easy to use Storm Monkey??
I dont want to make a mess of it!!
i have used a couple. my mate has a big karcher car cleaner thing so i used that. have used the special soap and also autoglym but the old faithful stardrops takes some beating.
Procedure with most products is...
Vac the whole interior from top to bottom thouroughly.
Test the chosen product on a small inconspiuous area.
Apply product with even distribution (sometimes slightly more on bad area's)
Now either agitate with an interior brush (good to have a bucket or similar to dip the brush into) then vac,or simply leave and vac.
Neil. :)
Be prepared for the car to steam up if you are doing it at this time of year. Plenty of driving with the sun roof on tilt/windows open (Brrrr!) and the heater going flat out on the lower vent setting will help the drying process and prevent it going musty.
Goldie
It was not too bad to use. I used it fairly liberally on carpets, as the rougher texture does not tend to show water marks. SiMply sprayed on, aggitate with a soft nail brush, and wipe off with a damp cloth. It got the coffee stains out of my front passenger foot well first attempt (damn lack of mug holder!). You need to be a little more sparing on smoother cloth or headliner, as if you get it too wet, it may mark when it dries. I used it very lightly on our old Audi seats, which were a light beige cloth, and wiped with a well wrung out cloth, and they came up a treat.
Hope this helps!
Phil
Nice one Phil..
To be honest the carpets arent filthy, id just like to spruce them up a bit and the headlining is perfect...
Shouldnt be too bad a job fingers crossed...
How long did it take for your car to dry out afterwards??
I left the seats overnight in the Audi, and they were ok, but it was a bit warmer and drier then. Not sure about the carpets, but with a bit of heat and not too mych water when washing, then they should be pretty dry the next day, and completely dry in 2-3 days at the moment.
Phil
Or, plug a hairdryer in and trail it into the car. Wrap the lead around the rear view mirror and switch on for a while to aid the drying process. Leave the windows slightly open for the steam to escape.
That is assuming youre firly close to a power supply ie house, garage
Ill give that a whirl Stan 24v when i do it..
I just dont want a car thats gonna mist up all the time...
