heyzy 0 Posted January 2, 2007 My ABS light keeps coming on every now and again getting more frequent. It comes on when you start the car and stays on.I know its not a sensor because i have hed one go in the past and you normally have to move drive the car for it to come on. Also every now and again when i first drive the car i can hear the pump making a noise and the braking goes funny. The weird thing his i got my local dealer to put the VAG diagnostics on it whilst he was reprograming a new key. But it came back with no error messages. Anybody else had anything similar. Cheers. Quote Share this post Link to post Share on other sites
kongo127 0 Posted January 2, 2007 I had a similar issue. The ABS light came on every now and then. When i start driving it was OK, then after a bump the light was coming on. I inspected the wiring and found no damages, so i disconected the sensor and gave a good clean with some spray. It doesn´t come on for almost a month, so i guess i´m sorted... :) Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted January 2, 2007 mine did the same, was a duff wheel sensor. Put your multimeter on resistance, check across the little black plugs on the suspension turrets - one will have a relatively low resistance and one will be infinite - replace the infinite one Quote Share this post Link to post Share on other sites
