trevor
master cylinder
i'm looking for a bigger master cylender for my 312mm upgrade . now fitted to the corrado 16v . i've been told that you can get a vw/audi one that has a 24mm bore but the big question is what car do i have to look out for to get one off .please help
You can use a 24-mm bore master cylinder from a Corrado or pre 95 Golf 3/Passat with ABS but you also need to fit the matching servo. You will have a device sticking out of the servo that is a pedal movement sensor for the ABS. You can either leave it in place or make up a blank and extremely carefully (and perfectly to avoid air leaks) weld this up if you want it to look right.
