a98pmalcolm
ABS light on no power ABS light off power
Hay people just asking for help. My ABS light is on when i start my G60 and all that works is my headlight then i dive for around 10 mins the ABS light turns off and all the electrics are back like my sunroof, heated window, fog ect and then 15 mins later my ABS light is back on but the electrics not working (30% of the time they can with the ABS light on)
Can Any one help?? This is such a pain when its rains coz the wipers wont work nor heaters!!
I cleaned the relays!! But still the Problem!!
Hmm, ignition switch problems? Maybe the load-cut relay not cutting out (it's supposed to cut off all your other electrical loads while the starter motor operates)?
That must be a dodgy electrical connection somewhere.
Because even of you have a defective ABS unit, it´s not connected to the same interior circuits.
Several faulty relays is almost impossibe too...
So i guess you need to get a multimeter and track the connections.
would that be the releif relay playing up ,dont they all run through that ,think its x relief relay or something like that ?
