Azz turbo 0 Posted January 11, 2007 i keep seein all these corrados with the wheels popin out from the car shell. i have bein told this is done with spacesers. is this true and if so where would i get them from. i have 4 stud at the moment. cheers aaron Quote Share this post Link to post Share on other sites
herisites 0 Posted January 11, 2007 Its actually the offset of the wheels that make the wheels stick out. Mine is a good example of offset as my front wheels (et30) are 9x16's and are under the arch with 3mm spacers (make it et27) on to clear the calipers and my rears are exactly the same size wheels but have a much lower offset (et15) and stick out past the arches with NO spacers on at all. However if yours is a 4 stud that means its not a VR6 which means your tracking is not as wide so they wont stick out as far on yours. Quote Share this post Link to post Share on other sites
Azz turbo 0 Posted January 11, 2007 thats a shame. really like the look you have on your car. Quote Share this post Link to post Share on other sites
herisites 0 Posted January 11, 2007 If you got some wheels the same size and offset (9x16 et15) they will still stick out a fair bit on yours, just not AS far as on the VR6 due to the wider tracking. Im not sure whether there is a way of sticking them right out other than using spacers. Someone else may be able to help out. Quote Share this post Link to post Share on other sites
herisites 0 Posted January 11, 2007 If you want to see how these size wheels look on a 4 stud corrado then check out g60greeny's gallery: http://the-corrado.net/.archive/forum/viewtopic.php?t=29983&postdays=0&postorder=asc&start=0 He has Borbet's on his but are exactly the same size as mine, should give you an idea :) Quote Share this post Link to post Share on other sites
