shephard
problems removing alternator belt
i went to change the alternator belt as it is a bit squeaky and realised the power steering belt is in the way but cant work out how to get it off to remove the alternator belt can anyone please tell me if there is a special tool needed or any gudelines on how to remove it please, would be very grateful as i am putting it in for mot next week and want to spend as less as i can, thanks
you need to loosen the mounting bolts for the front PS pump bracket (so the pump can swing - 2 13mm bolts inside the alloy bracket that go through into the back of the body of the pump) and then remove the adjuster bolt between the pump and the smaller bracket on the side of the engine, you won't get enough adjustment if you just try to turn it.
Then you can swing the pump towards the back of the engine as far as it will go i.e. pushing the two pulleys together, ps pump one and crank end one.
The PS belt will then come off, giving you access to the alternator one.
David.
