sciroccotune 0 Posted February 1, 2007 Hey all, Sorry its not a corrado question but i think you guys may be able to help. i want to know what it would take etc to get ABS on a mk1 chassis (in fact on a scirocco) I would probs use teh system of a 16v corrado or early mk3, just a 3 chan setup with no lanch etc. thanks any info is gr8 8) Quote Share this post Link to post Share on other sites
Crasher 3 Posted February 1, 2007 I'm just part way through one on a Golf 1 and I am using the system from a left hand drive G60 but a Corrado RHD with ABS would make a good donor as the servo would fit straight onto your servo bracket after swapping the operating clevis. The hardest part (without going to Golf 2 hubs) is the front speed sensor mounting points. One bridge I have yet to cross is that I have converted this car to a post 84 rear floorpan so like you (I presume it’s an 84 onwards model) I now have no rear pressure regulator and that’s could be a problem. The Golf 1 floorpan has negative offset steering geometry so that’s the main hurdle cleared. Quote Share this post Link to post Share on other sites
