trevor
vr6 boost
vr6 turbo charged . two questions . sorry three questions .
1 how much boost on a standard engine and what power? safely
2 how do i lower the compression fat head gasket ? shorter rods ? or change the pistons ?
3 does the vr6 fit on the o2m 6 speed box with 4x4 tranfer fitted .
The VR can take somewhere around 500whp
Most people will use a thicker headgasket
A tranny off a 4cyl will not bolt up to a 6cyl block
Safe =15psi ~ 400hp. The engine can hold more, but the gearbox is the weak link. 15 psi should hold for ages so long as you're sensible in the lower gears in the dry.
Forged low CR pistons best for high hp, stock pistons OK up to about 400-450hp. Stock rods have held 600hp. Good spacer gaskets work well.
O2M from 24V cars fits, but needs various modifications to gearbox and front engine mounts.
