dnac 0 Posted February 6, 2007 As above, what year must a car have a CAT, and what happens come MOT time if you remove it? I was thinking about getting a CAT replacement pipe for mine, and just putting the CAT back on come MOT time? Quote Share this post Link to post Share on other sites
Guest Posted February 6, 2007 does depend on model of car but should start around 1992 if you remove it and dont know the tester then its a fail so put your cat on then take it for mot Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 6, 2007 End of August 1992. Just swap the cat back on for the MOT. Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 6, 2007 You can get a cat bypass replacement just make sure it looks like a cat', like the ones on awsome gti. It'll then depend on the emissions, if you emissions fail with the bypass you'll have to put the cat back on for the MOT, once it passes you can switch it back. There was a thread very recently discussing a similar issue.... Quote Share this post Link to post Share on other sites
Guest Posted February 6, 2007 to be honest i aint seen one with a cat bypass passing emissions but good luck anyway. i would do what no crap says just fit it so it passes MOT Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 6, 2007 It does seem to be the option with the least hassle factor. Quote Share this post Link to post Share on other sites
jslootweg 0 Posted February 6, 2007 When I had my MOT done at christmas and my car is a K reg. There was no pre cat/ after cat test. There for they didn't test my cat. Surely this means I don't need one! Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 6, 2007 Just reading from a google search, it appears that so long as your car passes an emissions test using the test based on your car having a cat, its fine not to have one on there. Quote Share this post Link to post Share on other sites
