-Neil- 0 Posted February 7, 2007 Been having a think and wanting to get rid of the oil filler cap so have a smooth engine cover. I will still have the screw cap there but just covered. Apart from neding to remove the cover if i need to fill up, which in the 6 months of having the car i've not need to yet, will it cause any other problems? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted February 7, 2007 Nope, wouldnt have thought so, how you gonna remove the enigne cover if you need a topup in a hurry?? Quote Share this post Link to post Share on other sites
antera309 0 Posted February 7, 2007 You might be able to use an L-shaped bit of samco hose and a funnel - just pop it onto the crankcase breather flange as and when required... Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 7, 2007 why....its like solid inlet manifolds,welded up and smoothed so you have to take off the hole manifold just to change plugs. Is it just me? Quote Share this post Link to post Share on other sites
