1st rado for me
Power Steering problems
Hi Guys
I have a problem with my power steering, sometimes when I turn either way during the turn lose power steering then it comes back.
Fluid is full I know the the rack is worn and will need replacing sooner or later but I was hoping to change at the same time as suspension and wishbones etc.
Any ideas to what the problem is? Could it be the pump?
cheers
sorry poseted in wrong section, how can I move this?
Hi Guys
cheers
could be valves in the rack, the valve in the pump or a slipping belt, change the belt/check the tension on it they can slip from splashed water.
