ZippyVR6
major service time, What else Might I need?
Right then, The engine needs a bit of TLC and a major service, my guy has said I should get the parts needed. Im just wondering if I have got all the things I need on my list and as ever bow down to the knowledge harnessed in the engine bay forum.
Please let me know if there is anything Ive missed out.
Plugs, 6 NGK Platinum
Oil, 6 litres of Synta Silver
Oil filter ? Whatever GSF recomend ?
Air filter. None needed although the K&N could do with a clean.
HT Leads, Beru ones? for a Dizzy VR.
Other things needed.
carb cleaner for the ISV
Front Mount, Standard VAG one, (Not fussed with solid mounts).
anything else I will need?
Cool thanks ben16v, . Ill have a search on here for recomended oils and fluids.
although is there such a thing as a service pack that has all the standard things you I would need for a service?
Now I don't really have a clue, I just go with what Stealth and Vince say but....
they dont recommend VAG front mounts and if you were taking it there they would fit a Vibratechnics.
I'm sure others on here can explain why they are better than VAG!!!
Good luck with the final bill.
Yeah, even a new standard mount is too soggy really for the VR and won't help gearchanges etc - when they let go they stick a nice dent in the bonnet!
Another vote for the VT front mount here too, I fitted that and followed the instructions on the Deisel Geek website for setting up their short shift kit (even though I use the standard shift) and cured the baulky selection of 1st and 2nd. Gearchange is still a long throw when I've been driving the S3 all week but it's way slicker 8)
Im thinking that fitting a solid front mount will inevitably cause more stress on the rear mount, and when I spoke to Vince about one he quoted me upwards of 150 quid. The VAG one is 26 + VAT. Besides the VW one has lasted 14 years. I only need to fit a new one because it is weeping.
