balboa 0 Posted February 21, 2007 hi guys.......have a mk2 golf vr6...over the past few days as im drivin the car there seems to be coolant smoking from the radiator...ive had a look and cant see any leaks on any of the pipes....the smokin appears to be coming from the whole radiator....im guessing the radiator is knackerd and needs to be replaced.....??? is that the case.....many thanks in advance.!!! Quote Share this post Link to post Share on other sites
coolrado 0 Posted February 21, 2007 if your coolant level hasnt dropped and you cant find any leaks its most probably just moisture evapourating off the radiator when it gets warm. has it been raining where you are or have you recently washed the car? Quote Share this post Link to post Share on other sites
balboa 0 Posted February 21, 2007 oh yes forgot to mention.....coolant level is dropping Quote Share this post Link to post Share on other sites
