jonnyboyo
OIL WARNING LAMP & BUZZER
The lamp and warning buzzer seem to have a mind of there own. On some journeys they come on and on others they don't. Oil & water levels are spot on and the car drives fine.
Bizzarely, if i give the full beam a quick flash the buzzer stops. Then starts again!
Which sensor would i need to replace if any, and where is it located in the engine bay? Prices & part numbers would be cool too.
My car is a 1990 1.8 valver with 122k on the clock. Your infinite wisdom is much appreciated :notworthy:
CRASHER--as far as i'm aware the matrix aint leaking. No funny smells or leaks and the heaters work like a blast furnace. Not sure if the matrix was done b4 my ownership though. Is there a link there then mate??
DUB-- Ok will do, but where is it?!! and is there just one? There is a white sensor and a brown sensor on the oil filter mount, are they the ones?
Mine has started doing this again recently and having read this thread, i tried a quick flash of the main beam and the bleeping/flashing stopped!!!
Curious though crasher, what would the heater matrix have to do with it? Mine is about to give up i reckon as the heater aint what it used to be!!
Cheers and TTT!!!
