Rhodri
Changing inlet manifold from 42mm to 50mm??
I want to change my inlet manifold from the standard 42mm to the bigger 50mm on my 2.0 16v.
Is it a straight forward swap or do i need anything else? I will be changing the throttle body to a 1.8 16v one which has been ported and gasflowed
Cheers Rhodri
gaskets are quite expensive, about £10 each i think.
Remove injectors when the engines warm, they come out easy then
so need a gasket in between top and bottom intake do we also need a gasket
where the bottom intake attaches to the engine ? the other thing thats i havebeen thinkin about is what difference would gas flowin the manifold would make . where would the increase in power be if any at all ?
cheers fellas
I flowed my old 50mm one, you prob wont feel any difference.
The head to manifold gaskets are the same whether 42mm or 50mm
could i reuse the one thats on there or will it be safer to get a new one . cheers flusted
hows the knee?
hows the knee?
Did you flow and port yours yourself if so is it easy because i just dont have the skills to do it myself if its difficult. :(
Would also like to change from 42 to 50 thou on my 1.8 16v
its prob not worth doing to be honest, i just did it as i was bored at work :lol: id stick with a 42mm 1 all day long
