ziderapple 0 Posted February 23, 2007 Ok, one for the valver guru's, I'm buying a car with a 16v k-jet lump in it, which runs, but is "boggy as hell", this starterd when the previous owner was racing a BMW at silly speeds 120+, he said all of a sudden the power just went, so I'm thinking it may have jumped a tooth, of possibly sucked some muck into the meetering head. What would your suggestions be? Thanks. Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted February 23, 2007 I would have thought the vacuum hoses need checking, may have split one or even had one pop off. Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 23, 2007 Yeah, look for the small before worrying about the big. Get those hoses checked like Rustynuts said, check the sparkplugs and other ignition parts, make sure both fuel pumps are going and change the fuel filter......basically just make sure you give it a good service. Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted February 23, 2007 Does it rev hard? its either fuel/fueling or had lack of fuel in it. slow to rev sounds like timing. god he must have been hard on it Quote Share this post Link to post Share on other sites
ziderapple 0 Posted February 23, 2007 To be honest I'm picking it up tommorrow morning, only had it running on the chaps drive the other day, as it is SORN, and MOT less with siezed rear brakes, one thing is the clamping bracket from the manifold to exhaust is hanging off, could a lack of back pressure make it boggy? I've not driven it yet so can say how it feels, but it was enough for him to take the car off the road and let it sit, but it did get him the 20+ miles home with no probs thou. (I know it may sound daft buying a car I havnt driven, but I know its straight and I got it for silly money) Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted February 23, 2007 I had a similar problem with my KR, but this was intermitant bogging on full throttle, this turned out to be the fuel filter that I had neglected to change... :oops: Quote Share this post Link to post Share on other sites
Crasher 3 Posted February 23, 2007 Check the basics first, valve and ign timing. Quote Share this post Link to post Share on other sites
gixxer 0 Posted February 24, 2007 Had this recently on mine. Turned out it was a split in a vacuum hose. Quote Share this post Link to post Share on other sites
ziderapple 0 Posted February 24, 2007 Well picked I it up today, while it was on the blokes drive, I jacked it up, bolted up the split exhaust clamp and voila!! My brother and I had to tow it across Bristol but I had the engine running for the Servo assistance with the brakes, when I got it home I had a qucik go up a quiet road - it flies!! Gearbox is hardwork though, very notchy, would imagine that its a linkage issue though, it pulls and sounds good. Its a Mk1 Golf by the way, it does need a good service though, so will do the works including Cam belt, arm, cap and leads then she'll be a winner!! Thanks for the replies. Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted March 1, 2007 Anyone know you'd fix a linkage problem? Quote Share this post Link to post Share on other sites
