RS VR6
Anyone get this code?
Got this code ramdomly today. It showed up twice as I was in traffic.
I got no real answer searching.
Where is the O2 sensor heater relay(Z19)?
Lambda Sensor, G39
- Signal to B+
- Signal to ground
- No change in signal
Possible Fault Conditions
Open circuit to J220
Lambda sensor heater (Z19) faulty Where is it located?
Fuse for Z19 blown
G39 faulty, recently replaced
Signal wire short to ground or shielding
Ignition system failure
Intake leak after mass air flow sensor (G70)
Leak in exhaust system before catalysts
Ground wire between pin 10 (which is pin 10?) on J220 and engine block open circuit
I checked the wiring last night...everything seemed fine.
Lol...just remembered...for the Z19 relay location, all I have to do is perform the output test on my Vag Com. If it clicks its still good.
