delfinis38
General service..
just trying to get the energy together to go and change the oil and filter in the rado this morning. Thought i might check the air filter and plugs... not taken the plugs out myself of the VR any special tool required and what should the plug gap be.
TIA
Hi
Leave the plugs alone, you need a special tool to unplug the leads.
Do a search for my threads about the oil filter
You need a metal 'hazet' tool but you should have a plastic version on the car somewhere. Check on the bonnet stay or in the tools in the spare wheel well.
If you buy the right plugs they'll be ready to go straight in.
Thanks chaps all sorted apart from the plugs... Tried to have a look at number two cylinder. Look the easiest one to start with and decided to leave well alone until i had the correct tool... Cant find a plastic tool on the car :?
Plastic tool will either be on the bonnet stay pr clipped to the jack handle (or missing :lol:)
and is as much use as if its missing.....................good for clipping to the bonnet stay and making your car look like its out of the showroom tho :lol: :lol:
