swfblade 0 Posted March 15, 2007 Just recently, my VR6 has been a little bit hesitant, as in when I'm not on 100% throttle it wants to go, then drops power, then starts to pick up again. It also feels a little bit flat sometimes, like all the powers been taken away. Admittedly the fuel pumps a little loud, but its been like that since I brought her. Maybe worth a fuel filter change do you think? Quote Share this post Link to post Share on other sites
adevr6 0 Posted March 15, 2007 check leads/coilpack.clean throttle out-all cost nowt.clean hall sender[also cost nowt].vag com for faults.leads to coilpack need good connection[arcing-check]. hope this helps. Quote Share this post Link to post Share on other sites
swfblade 0 Posted March 15, 2007 forgot to say, had a service a month ago, where leads & plugs were changed for new, and vagcom only pointed out the failing ABS sensor at that time. Admitedly that was a month ago now, but still new plugs and leasds shouldnt be an issue. Quote Share this post Link to post Share on other sites
swfblade 0 Posted March 15, 2007 oh and which ones the hall sender? Quote Share this post Link to post Share on other sites
Taggart 0 Posted March 15, 2007 Did they use the right plugs and leads (ie not cheapo ones) and are the leads sat right? Quote Share this post Link to post Share on other sites
mtc R32 0 Posted March 15, 2007 Possibly the famous MAF sensor..... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 15, 2007 Or the cam position sensor (aka hall sender). Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted May 23, 2007 Ive got a Cam position sensor, i replaced with a new one, if you want to give it a shot. Bought a new one with the adivce it'd solve a problem and didnt. So the old sensor must be working. Just pay for postage if you want it. Gaz Quote Share this post Link to post Share on other sites
