weskos
ECU VACCUM LINE??
Does anyone know whick inlet the ecu vaccum line goes int on the back if the inlet manifold? is it the bottom or the top? Thanks and PLEASE let me know. Cheers.
The lower nipple. If you have no carbon canister then block of the upper nipple. halfrauds sell 1 m of perfect 3mm bore Diesel over run hose, it comes with a few rubber blanks to close of un-needed Diesel injector outlets.
