cvw 0 Posted April 3, 2007 how important are Nm bolt settings ? Quote Share this post Link to post Share on other sites
Taggart 0 Posted April 3, 2007 Depends where it is! I wouldn't want my brakes done up to 5Nm.... Quote Share this post Link to post Share on other sites
Toad 0 Posted April 3, 2007 I don't generally tend to use a torque wrench. I just do things up tight. A bit of common sense will see you through on most things. I would always use a torque wrench for head bolts and the like. Quote Share this post Link to post Share on other sites
g60bv 0 Posted April 4, 2007 well after not doing the flywheel bolts up to the correct nm setting . the flywheel came loose and shook my engine to bits. complete rebuild. £1500. so yeah if its says x nm do it.. Quote Share this post Link to post Share on other sites
Rob Heath 0 Posted April 5, 2007 I rarely use a torque ratchet, unless its somethin critical like a head etc. Judge it by the size of the pin, if its only a small bolt, dont go crazy on it Quote Share this post Link to post Share on other sites
Yandards 0 Posted April 5, 2007 how important are Nm bolt settings ? Very. Torque figures are there for a reason, on all components. Quote Share this post Link to post Share on other sites
zuko 0 Posted April 6, 2007 What about split rims? Do u lads use torque ratchet for that? Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted April 6, 2007 Definitely need one for split rims. Quote Share this post Link to post Share on other sites
