Cnut 0 Posted April 4, 2007 Ever since my VR6 was taken out of storage for the winter it has been rather poorly. It tends to judder and misfire when you put your foot down in a high gear at low revs (1000-2500) but it is also quite intermitant. So far I have changed the coil pack which was arching - that made no difference at all. The spark plugs and ht leads which made it 80% better but still the problem is there but less pronounced than it use to be. Does anyone have any suggestions as to what could be causing the problem. I have searched the threads but found no definitive answer. It has also backfired once when reving the engine stationary. Cheers Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted April 4, 2007 your ISV will make it run lumpy if knackered Quote Share this post Link to post Share on other sites
Cnut 0 Posted April 4, 2007 It might actually be related to that because it was idling like a bag of nails after storage then I got someone to clean it out and it idled perfectly again. I forgot to mention that the little braided rubber pipe that connects to a pot alongside the injectors was replaced because it had a split in it and thats when all the symptons started... Quote Share this post Link to post Share on other sites
latestarter2 0 Posted April 5, 2007 is this ISV easy to change? mines a bit lumpy on tick over too. Quote Share this post Link to post Share on other sites
Cnut 0 Posted April 5, 2007 is this ISV easy to change? mines a bit lumpy on tick over too. Its very easy to replace but i would try cleaning out with carb cleaner first (plenty of threads on it) Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted April 6, 2007 Could well be one of your injectors if the replacement of the fuel regulator pipe started the problems.... Whip out each of the plugs, if one is all wet with fuel then thats your problem, the injector is not misting problem. Jay Quote Share this post Link to post Share on other sites
Jim 2 Posted April 6, 2007 Hm.. been wondering what could cause similar probs on my valver and have suspected a bad injector for some time. Thanks for that Jay.. think it answers my question. Quote Share this post Link to post Share on other sites
