Dubrider 0 Posted April 5, 2007 help... got a charged vr but it keeps cutting out @ low revs. ive herd that the maf needs a constant live, could this be the reason it cuts out?? Quote Share this post Link to post Share on other sites
fla 9 Posted April 9, 2007 Quite extensively covered already mate but just in case here are a few checks to do: 1. Check your ISV is clean and lubed 2. Clean the throttle body with carb cleaner 3. Check your ECU relay number 109 4. Check the fuel pump (not really likely to have failed) by the whine at tickover 5. Check the MAF wire is not broken 6. If you can borrow a Crank position sensor swop that over and try again. HTH Quote Share this post Link to post Share on other sites
