valverado 0 Posted April 10, 2007 Hello guys Need some help please. Me exhaust is making a rattling noise but all the Exhaust mounts & Heat Shields are ok. A mate has told me it sounds like the front engine mount. Could this be the case? Ive looked in German & Swedish Brochure but they dont do mounts for the corrado, Is it the same as Mk2 GTI? Any help will be appreciated..........Thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 10, 2007 GSF do a front mount for the corrado, they seem OK, unlike the rear ones they do which are pants, far too hard. I recommend you go for at least a FEBI one (AVS) and preferably VW for the rear but it's the fronts that suffer the most wear and it's usually those that fail, the engine will rock really badly if you put it in gear and lift the clutch slightly against the brakes. Of course your rattle could be a loose baffle inside an exhaust silencer? Quote Share this post Link to post Share on other sites
jonnyboyo 0 Posted April 11, 2007 Do the clutch test as mentioned above. Thats what i did to tell that my front mount was goosed. GSF do the front mount for £37 incl vat. I just looked on the AVS site and they are £38, not sure if this is with vat though. I think i'll go with the AVS jobbie on davidworts recommendation, as not all things said about GSF parts is good. Quote Share this post Link to post Share on other sites
valverado 0 Posted April 11, 2007 Cheers guys ill give the clutch test a go and let you know. :mrgreen: Quote Share this post Link to post Share on other sites
Garry 0 Posted April 11, 2007 I had a similar problem on my MK1 Golf. It turned out to be the down pipe/manifold joint blowing. Quote Share this post Link to post Share on other sites
