Hass
Vr6 Conversion
Hello Peeps! I need some help with a Conversion i wanna carry out in replacement of my 2.0l 16v lump to a vr6, so far ive got the Engine, Gearbox, ECU, Loom, Driveshafts, Wishbones, Subframe, Powersteering rack,nology hotwires?, and a piper x Induction. What else do i need other then the Brakes and suspension as the current brake discs and shocks are dead so they need replacing anyway!, Heard ill have to get a Downpipe which ive seen a used one but im not sure on what else is required!, Please Help! Thanks :?
Theres a guy on here who is in the process of doing this...
I think his name is Quicky1980 or something close to that - id try and get in touch with him for some good advice....
Hello!, My Engines messed up on my current Corrado, Ive spent loads on other bits bringing it back to life and didnt want to sell it after so many birthdays worth of money going into it, Found a Engine and bits at a really good price just wanted to make sure it had nothing missing as i was planning to put a normal 9A engine back in but wanted something with more grunt!
I dont blame you for keeping the car but i think id be wanting to put something a little different in.. 1.8t or 24v or such alike...
The 1.8t is meant to be a straightforward job....
Its sourcing a decent Engine, Plus the costs ive been given to carry out a Turbo conversion to a VR6 is about £2k difference, they Company im using is voodoomotorsports.co.uk, They specialise in V-Dub conversions and said it was the easiest option for me as i can always put a super charger on later in life?
I converted my 1991 G60 to a VR6 earlier this year. Putting VR6 in a Corrado is pretty easy, there where a few bits which I needed to change.
Here's a list of the major parts require
Engine/ Gearbox
Engine loom with fan relay
Key reader around barrel
Transponder box with loom to Key reader and OBD2 port (this will change if OBD1)
Corrado front cross member from VR6
Corrado Airbox and 4 pin air mass meter
There were a few other bits and piece need along the way too but can't remember.
The following items I didn't bother with as I was not changing the hubs etc
NO DRIVESHAFTS
NO HUBS/DISCS/
NO REAR SUBFRAME
NO POWER STEERING RACK
Hope this helps.
