adamukcorrado 0 Posted April 21, 2007 car's been off the road for about 8 months and trying to get her going again. have found a major oil leak. it's coming from a round hole about half way up the drivers side of of my vr engine block just below the top wheel of the alternator belt. when engine's running oil literally runs out of hole, but stops when you turn engine off. i need to know what the hole is and why its leaking so badly. IT'S NOW LOOKING LIKE A 'CORE PLUG'(?) ANYONE KNOW HOW TO FIX IT?? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 21, 2007 Can you put your finger in there? There is a kind of metal plug- looks like it's either missing or damaged. Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 thats the strange thing, the hole is only about 5mm deep and there are no sharp edges or clean edges indicating a bolt or plug has sheared off. it also seems far too tight to the pully wheel to fit anything like a bolthead on the outside. Any ideas?? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 21, 2007 Had a look at mine earlier, and it looks the same as yours. I think it has a kind of 'indented' plug, a bit like the one for the gearbox oil. Quote Share this post Link to post Share on other sites
double-6s 0 Posted April 21, 2007 If there's a hole and it's p*ssing oil, i'd say there should definately be a plug of some sort in there! Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 thanks for having a look, i really hope it is something as straight forward(?) as a plug need replacing. gone over rest of car and is gonna be fantasic when going again as nothing else too serious needs doing, so fingers crossed it'll be an easy fix! any one else got any ideas??? Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 there appears to be some sort of plug in there already- hole is only a few mil deep, but there is no apparent threads or allen key holes to remove whats there...... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 21, 2007 Take a look in ETKA, or go down your local dealer and ask them to take a look in ETKA.. Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 whats ETKA? the computer programe with all the parts and locations? i'll try it tomorrow, my local dealer is rubbish tho- mention a corrado and they just look at you blankly! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 21, 2007 Tell 'em to look at the diagrams for the Golf/Sharan VR6 - the engine block is about the same ... Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 yeah, will do (my engine is sourced from a very strange place anyway - not sure where from, but not a uk corrado anyway!) Any idea how to remove & replace the other plugs-(such as gear box plug mentioned above)? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 21, 2007 You need a 17mm socket plug remover- you can get them from Halfords. Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted April 21, 2007 Its an engine core plug,vw number N0119103 £0.54 from vw Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 fantastic!!! :cheers: what the best way to remove old one and fit new one? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 21, 2007 Here's the gearbox oil socket thingy ;) Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 21, 2007 don't forget to check the oil pressure. i may have blown out due to high pressure. Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 21, 2007 i may have blown out due to high pressure. now normally i wouldn't sink to dinkus' level but... :lol: Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 one of the last things i had replaced before i got p**sed off with wasting money on it and took it off the road, was the oil pump, so that may of blown the old tired plug. but how do you replace a core plug? please please don't tell me you need to 'cork' the hole from the inside!! becuse that would be typical corrado- having to spend fortune opening engine to replace 54 pence worth of plug! :roll: Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 21, 2007 probably just clean up the block and hammer it in? Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 21, 2007 Any idea how to get old one out without getting bits in the engine tho?? Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 22, 2007 anybody know how to remove old core plug and replace? Quote Share this post Link to post Share on other sites
ziderapple 0 Posted April 22, 2007 no idea, but you could always jack the car up, take off the wheel and inner plastic arches, drill a very small hole into it, tap it out, put a bolt in it and yank it out- that may be aload of rubbish though. Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted April 22, 2007 not really got good enough access to get a drill to it with engine in situ, must be an easier way..... Quote Share this post Link to post Share on other sites
Rob Heath 0 Posted April 22, 2007 You dont want to be gettin any swarf in the engine either. Not done a core plug before, maybe weld a bolt onto it (if possible) and get a socket onto it. When weldin, only do short bursts (tacking) as this should stop the heat warping the plug/surrounding area Quote Share this post Link to post Share on other sites
